New Remote wanted
cheyworth
145
I am looking to replace my TV (LG 42PG3000), AMP (NAD T163), DVD (Philips DVP5980), CD (TAG Mc CD20R), remotes with an all in one unit Any suggestions?
I would like back light and easy programing.
Chris
a.g.
12
I have the Cambridge Audio M1+ learning remote. It can be had very cheap on eBay and is good as long as you only need the most common buttons, as the scope for customisation is limited by the number of "buttons" and manufacturer set labels.
Willow132
7
I've got the logitech harmony 1000. I've had it about a 3 months now and cant fault it at all. Its easy to programme as well.
Just in the process of buying an RF extender so you can hide the equipment away and still use the remote. Which is another reason i went for the harmony range
