New Philips 9704 LED TVs
Nope just checked the 46 inch one is only 29kg with stand.
From the manual; 32PFL9604, 20Kg, 37PFL9604, 29Kg, 40" 9704, 33Kg, 46"9704, 41Kg, 52" 9704, 49Kg.
I don't think it's likely that all these figures are wrong or misprints. Do you?
Harrowman:
Hmmm....very unusual! I don't think Philips LED (LCD) TVs are heavier than plasma TVs, do you?
The manuals are printed elsewhere & aren't always correct.
Check Philips' website: http://www.consumer.philips.com/c/televisions-9000-series/9000-led-pro-series-40-inch-full-hd-1080p-digital-tv-40pfl9704h_12/prd/gb/
Harrowman:
How heavy does it feel?
With great difficulty I have just hoisted the TV onto my bathroom scales. Yep 33Kg on the nose. Perhaps my scales are a bit out but not that much.
Clare you are testing this tv at the moment how heavy is it.
It's chunkier than the average LCD, that's for sure. Sadly I don't have any weighing scales to hand, but i'll ask Philips for clarification - if anyone's around this close to Christmas....
I see what you are saying know Bigboss, this is very strange.
gel:
That's with the stand according to philips website Bigboss, without it was around 20kg.
Philips can't even weigh its TVs properly! The link I posted weighs the Philips at 27.4kg with the stands. Let's gift a good pair of bathroom scales to Philips this Christmas!
You may well be right. But looking at the stand I would not think it weighed 10Kg, I could be wrong. Anyway what does it matter what it weighs unless you expect to be moving it about every day.
Another point is that the depth of this set would make it difficult to wall mount especially as all the inputs connect to the back of the set. I suspect most users would use the set stand mounted.
My 32 inch philips lcd weigh's in around 22kg but it's about 4 year's old now I think.
I have just read the manual more carefully. The Weight is stated at 28Kg without the stand and 33Kg with the stand. This means the stand weighs 5Kg. That is very likely.
Just had confirmation from Philips- the stated weight in manual is wrong.
The 40PFL9704 weighs 22.6Kg with the stand and 19.8Kg without.
Clare Newsome:
Oh well, that puts an end to one of the most hotly debated topics! It even risked Harrowman's TV & his back while lifting it!!
Just to confirm Clare's findings. The zero on my bathroom scales was set incorrectly, have re-weighed at 24Kg within the margin of error for the scales +/- 2kg. They are fairly cheap scales. Hope this put a line under this weight thread.
Harrowman:Just to confirm Clare's findings. The zero on my bathroom scales was set incorrectly, have re-weighed at 24Kg within the margin of error for the scales +/- 2kg. They are fairly cheap scales. Hope this put a line under this weight thread.
That's good then that's the sort of weight I wanted it to be.
Next month's issue for the review then Clare?
Yep - Philips 40PFL9704 review in February issue; with subscribers from 2nd January; in shops by Wednesday 6th January.
Calling all Subscribers how has it done please?
I can't afford to this year
but I have yearly subscribed in the past - used to get it as a birthday present from my sister, I now get money instead but this year I got a t-shirt.
Come on Andrew, you can give me a hint, you must of seen it?
As you may have noticed, I've been away since December 16, and am now sitting in a lounge in Helsinki Airport waiting for a snow-delayed flight back to London.
So no, 'fraid I haven't...
You must be getting to know that Airport pretty well now?
You are not having much luck with the snow are you.
