- Aug 10, 2019
- 2,556
- 5
- 0
Hi all,
I'm looking to buy a new system, with a view to eventually connecting it up to a new LCD flatscreen when it is eventually purchased. I'm not too fussed about 5.1 or anything like that - I just don't have the space or wallet for that kind of stuff.
I am however a keen music lover and what's wrong with good ol' stereo anyway! I will probably want to include a sub at some point as well though.
Right now I'm pretty much set on the micro system we're getting, unless someone else has a better option for me. Again, due to the space options, I'm really keen on a micro hi-fi and not full sized seperates.
For this I was thinking of the ONKYO CR-715 (not the baby 315 version). I'm going with this because I believe through my research it is a great choice with top-end performance. Does anyone agree or disagree with this? i am also musing over the slightly CR-515 which is considerably cheaper, and I wonder what peoples general opinion is of this against the 715?
For the speakers I am torn between the Q Acoustics 1020, Q Acoustics 1030 or the Tannoy Mercury F1 Custom. The 1020's don't seem to have the extended bass I would like, the Tannoy are a little tall for my bookshelf but do have a slightly extended bass end ('cos they're bigger and more powerful) and the 1030's obviously are the most expensive and take up the most room, but do have a lower bottom end capacity. In case you didn't guess I like my reggae!!
To make matters more difficult to decide I notice the Q Acoustics people have brought the i series out - so there is the 1020i and 1030i to consider as well.
I know I have to sacrifice bottom end to an extent if I am getting small speakers because at a very basic level the thing that makes a speaker bassy is its ability to push air which is mainly due to the size of the woofer and the cabinet. Small speakers will never sound as big or full, but I wonder if anyone can offer any ideas here.
If anyone has any other ideas that I may have overlooked then please post some links to check out or tell me that they are and I'll look them up. Obviously I am aiming to spend the least possible, so please don't go crazy and suggest large Mission's (like M35i) of Kef's (like IQ9) because this is way way way way out of budget.
Ideally I'm looking to spend anywhere between £400 and £550 of our british pounds, although the lower the better.
Thanks to everyone in advance.
