How long ago was this Rick, and when are your next lot in? 🙂Something worth bearing in mind as it might help is that we had brand new H90's on sale @ £362 (RRP £1500).
In fact, your suggestion of adding a good streaming pre amplifier probably makes a lot of sense.
Dang. I remember when you were selling them. Gutted i didnt have the money for a 360....👍I’d have to check but I believe the last H90 was sold in 2019. No more as the H90 has been replaced with the H95 also @ a RRP of £1500 btw. Besides which we’re also no longer supporting them.
If it's too dear, I think the CXN v2 has the same functionality. And also I'd look into other brands as well, before making any purchase.Thanks for your answer.
It's probably worth the extra money on a preamp / dac. Others are recommending it to me too. I'll check Cambridge even if it's a little higher than my budget.
Correct me if I'm wrong, it doesn't really matter how good the current is if the tonal balance isn't right then its no good for the PMCs.I've got a lot of experience with Rotel amplification and their watts are not their for a marketing show. They have current rich power rather than current starved wattage. In the RB-870BX you've got a rock solid engine. So my advise will be to hold on to the RB-870BX and look at adding a streaming pre amplifier such as Auralic's Altair. The Altair should offer an uplift in performance throughout the fq. range and regardless of the genre of music you listen to. You should be able to find a demo or a used Altair at or within your budget.
Can I ask, DM, what speakers do you run with the Hegel?I did and bought one of Rick. Fantastic amp (H90). Sold that and later bought an H120. Hegel make very good amplifiers imho.
Hi PP
I use Kef Actives. With the Hegel 120 I used Quad S2's.
The H90 has a couple of analogue in's, the 120 also has a set of balanced ones.
Nice one. I've no experience with Quad equipment or Hegel. Presumably you use the Hegel with the actives as a preamp, or are they two separate entities?
I love those quads, and for some reason, I almost always forget to recommend them 🙂Hi PP
I just use Kef LS50W Metas these days. The Hegel/Quads were moved on.
I was trying to get a handle and if it helps the OP....I love those quads, and for some reason, I almost always forget to recommend them 🙂
you do realise it's about 3 times his budget?Good timing.
How about getting a demo of one of these?
I demo’d a much older amp and source from the same brand back when the GB1’s first came out. I thought it was a lovely combination, especially with classical
I must have missed that bityou do realise it's about 3 times his budget?
You are not the only one 🙂I must have missed that bit
