New better Cart for a budget TT ?
That extra weight is probably why I was told it would weigh to much. Daytona, I noticed on a separate thread you mentioned a HE or Shibatta stylus attached to the At95e, do you have any links for buying these in the UK, thanks.
Gonepostal said:
Interesting, on a website called snvinyl.co.uk it shows 6.5g. Perhaps it means the cartridge only.
That’s a typical cartridge weight. The headshell will be another 8 to 10 or more, depending on the design. Added to that are the fairly light screws and nuts to secure the cartridge.
