margetti:
.... but Netgear routers do seem to like a "reset to factory defaults" every so often - in my experience at least!
Hmm, my gd old mum has a netgear supplied by sky when she switched over and in the last 18 month has never needed a reset, however it not to say that this would not help. I would try removing the power from the router for a couple of minutes and reconnect, simply a reboot to the router, settings remian in tact. Are you sure nobody in the area is on the same channel as you ? e.g channel six, try changing this to a different one to see if it helps. It might be better to set the router to receive both B/G signals rather than B or G, it will allow it to cope with anything that may cause interference. I use a Linksys my self and a reboot now and again helps 10 fold, the electronics are given a chance to cool and once powered back on its happy as larry down the local.
HTH - sc00bie
