Netgear ReadyNAS Duo RND2000 - Squeezebox Server?
mattjax05
230
Hi
I'm looking ti buy the above product to work with my Squeezebox Receiver. I read that the above product comes embedded with Squeezebox Server (formerly Squeezecenter) Could anyone please confirm this and also if so what version is pre-installed.
Thanks, Matt
Vimeous:
Matt,
The full spec list for the device can be found here: http://www.netgear.co.uk/readynasduo.php?src="home"
It certainly looks like it'll do everything you need.
I looked at this but all it said is that it supports Squeezebox, not actual confirmation that it's pre-installed.
Vimeous: http://wiki.slimdevices.com/index.php/SqueezeCenter_on_ReadyNAS gives instructions on how to configure the ReadyNAS so give this a read first to see if it suits your need.
These instructions I believe are for installing Squeezebox Server yourself (something I'm trying to aviod!)
I would like a definitive answer from someone as to whether or not the SB Server is pre-installed please.
