Evening all,
I wonder if anyone would be kind enough to give their thoughts on the following please.
My hifi is set up in a room used as the home office and following a cut-down now just consists of my trusty Squeezebox 3 connected to a silent PC running the Squeezebox server (or whatever it's called nowadays) under Windows XP. I listen to music exclusively with Sennheiser wired headphones.
I would like to listen to music in the living room, however, do not want to move the Squeezebox from the office.
I initially considered buying a set of Sennheiser RS170 wireless headphones and simply connecting the transmitter to the RCA or headphone socket of the squeezebox. However, having read a lot about the RS170s I have read that although good quality wireless headphones such as these perfom well, it is likely that they will not be as good as a decent quality wired pair.
Looking for alternative ways of getting music from the office to the living room I came across the Audioengine W3 wireless music adapter to broadcast sound from one of the outputs of the Squeezebox to some wired headphones.
So I guess my question is twofold:
(1) Where does the majority of the reduction in sound quality with wireless headphones compared to wired ones occur? Is it in the transmitter/receiver, the headphone circuitry or both?
and
(2) Which option above would result in the best audio quality? Sennheiser Rs170s or Audioengine W3 connected to a decent set of wired headphones?
I appreciate that this question is probably difficult to answer as everyone has differing opinons as to what constitutes a "decent" set of wired headphones, however, any thoughts would be gratefully received.
Many thanks
Russ
and
Many thanks
Russ
