C43muz:
I have a Denon 2310, Pinoneer Kuro PDP Lx 5090, Monitor Audio Silver RX6 AV12, SKY+ HD, QED HDMI cables, Speaker wire was advised to get the same that is in Speakers. Basic mains, no power conditioner. I am not happy with the picture quality or sound quality, should I get different speaker wire, mains, a power conditioner? I also need a good Blue ray player. I am not happy with results and do not know what to do next or the best set-up for the TV, AV receiver. Please help as I am in over my head.......
You have a very good set of equipment which should be providing far more than acceptable performance. I would suggest having a look at the setup of your gear. There are some good guides on this site on how to set up (calibrate) your TV and your AVR. I would say that if, after having set it up to the best of your ability, you are still not impressed, you might try installing a power conditioner into your system. It may be possible that you have dirty mains in your home and this could be holding your system back. I moved house last year and when I re-setup my home theatre in the new house the sound and picture performance was extremely lacklustre compared to how it operated in my old flat, and it was even a much better proportioned room for acoustics! I was dumbfounded but after a few days of fiddling I grabbed a power conditioner from my studio and installed it in the living room and it was as though a thick duvet had been removed from each of the speakers and the telly definitely had more punch in the picture. It was even better than it was in the old flat so I would venture to guess that my old flat had decently clean mains whereas the new house had really poor mains. I would still suggest calibrating your system before purchasing any additional kit to make sure you are judging it on its best performance, but I did find that mains conditioning worked a miracle for me- and many users here have had great results with a very inexpensive unit in the tacima.
