Hi there, i was wondering if anyone could help with regarding purchase of a new home cinema amplifier? My budget is £350, and it must decode all the new Dolby HD audio, and of course sound good with 2 channel as well. I also like deep solid bass, and must produce a vivid surround stage, with plenty of volume in the rear channels, something my previous Denon (5.1 DTS / Dolby Digital) lacked.
The contenders from what i have researched are:
Sony STR-DA2400 ES – Yes i know its over £350 BUT i have found a refurb for £325 , and i must say this amp is my preference, as i would ideally want an amp that up scales SD DVD’s to 1080P, as i have a 50” 1080P Plasma. I currently have my Tag DVD plugged into the plasma directly via component - would upscaling via an amp make the picture any better??? If it would not then that would make a big differance in price's for which amps i would need
Yamaha DSP-AX763 – Great reviews but no upscaling and only x2 HDMI (I only need 2 at the moment, for SKY HD and PS3).
I would prefer the Yamaha DSP-AX863, but can’t find this less than £586 (too much money)
Onkyo TX-SR577 – good review in computer shopper recently but 4* in what hi fi Vs 5* for Yamaha DSP-AX763
Sony STR-DG820 – £280 and recommended by what hi fi, no upscaling (not seen the review), no idea if this is any better than Onkyo or 763.
Sony STR-DH800 – replacement to above, but how come what hi fi are still recommending the DG version?
As i have SKY HD, i would require any amp has manually configurable optical / HDMI inputs, in that i must assign video to HDMI and 5.1 sound to Toslink, otherwise ill only get 2 channel (i am aware this was a problem with the Yamaha’s, and Sony STR-DA2400 ES which has been fixed via a firmware update)
My system comprises of:
Panasonic TH-50PZ80B
Tag Mclaren DVD-32R
Tag McLaren AV-32R (Standard)
Sky HD (Samsung box)
PS3
Speakers - Kef Egg‘s KHT 2005.2
I play CD’s through my Tag, as i believe this will be a far better 2 channel source than the PS3 – would this be a correct assumption? Also, an additional question – to get the best sound, would it be best to connect a toslink direct from my DVD to my amp, or from my pre amp (AV32R) to my amp
If i go via toslink from my pre amp, will the signal be pre amp’d, or do i need to use the multi channel pre outs?? Not too hot at wiring things up!! I am presuming the toslink would be best, as its digital as opposed to analog.
Thanks for any help in advance
Regards
Phil
Tag Mclaren DVD-32R
PS3
Regards
Phil
