Need help choosing amplifier on tight budget?
Dec 18, 2014
I have a pair of TIBO edge 200 speakers and I'm planning on buying an amplifier for them, howver I am completely clueless about the watts and impedence ratings etc. Basically looking for an amp that costs around £50? Very tight student budget and would rather be able to use them than have the best quality sound at the moment.
Would something like this work? http://www.amazon.com/Lepai-LP-2020A-Tripath-Class-T-Amplifier/dp/B0049P6OTI/ref=sr_1_1?ie=UTF8&qid=1441144562&sr=8-1&keywords=amplifier
rainsoothe
hi
Check ebay or 2nd hand shops for Rotel RA820 or RA930 (AX or BX variations), or Nad 3020 for a warmer sound (no clue how you speakers sound - if they're warm and diffuse, go for Rotel, if they're bright and harsh sounding in the high frequency region, go for NAD; if they're neutral, go for either you thin you would prefer).
Can't comment on the one you linked, but chances are the used options I listed are better.
