Need a projector 20.5 inches or smaller
justfigured
Hello -
My theatre room has a drop down box that measures a total of 20.5 inches wide which disqualifies me from most of the new Epson line.
We usually watch movies early evening and there will be some ambient light
I have a projector budget of $3500 - 7500 or so and I'm looking at:
  • JVC NZ3
  • LG HU810PW
  • Epson 5050UB
  • Optoma UHZ65LV
Wondered if anybody has a strong feeling on these models or others I should consider?
Thank you!
abacus
All the above have different advantages and disadvantages and a visit to a dealer to see which you prefer is the only way to go. (Make sure the dealer sets the lighting level to match your own)
The type of screen will also make a big difference.
NOTE: Take your time choosing, as like speakers something that initially jumps out at you can end up being annoying long term. (As a rule of thumb if you sink back into the sofa and forget about the projector being used, that’s probably the one)
Bill
