drummerman
- Jan 18, 2008
- 540
- 5
- 0
I find it more puzzling that most 'studio' monitors look like the automotive equivalent of a tractor.
You'd need an understanding wife.
Gazzip said:Andrewjvt said:Gazzip said:Andrewjvt said:Gazzip said:Lots of advice flying around on this and other forums at the moment that we should ditch our audiofool passive bookshelf loudspeakers in favour of their less expensive active/passive studio cousins from the professional market. For my money this is really, really bad advice, but I would love to hear what others think.
I am pretty sure that studio nearfield monitors are not designed for listening to music. They are designed for listening through music, which enables the studio professional in the mix to hear what their tracks and mix are all doing. I have heard pro market Yamaha, Adam and Genolec Active NF’s and find them all way too analytical and...well...unmusical.
PMC make a studio range and a pro range of near field/bookshelf’s, as do ATC. I don’t know much about ATC but PMC have no crossover between the two versions (no pun intended). For PMC there are different horses for different courses.
I think what I am trying to say is that having a pro-market loudspeaker that can open up every nuance of the recording may not necessarily be portraying what the artist intended you to hear. They may be portraying what the engineer is meant to hear.
Listen to a PMC pro next to.a PMC hifi speaker of the same driver size/configuration and you will answer your own question. I think you'll be surprised how similar they sound.
The only difference between ATC pro and hifi range is the finish of the cabinets
The advantages of active over passive is nothing to do with hifi or studio monitoring application.
My studio monitors are very musical imo but as they are very cheap they have limits
As per my original post PMC do not have the same NF monitor loudspeakers in their consumer range as in their pro range, so the comparison you suggest is not possible. Pro NF monitors are designed for a specific, professional use, which is very different from home audio use. The two are not interchangeable in my opinion.
Is nf another word for small?
Near Field.
Andrewjvt said:I'm no expert on PMC But a quick look at the website and I can find lots of similar products and hifi models
Please explain how models could sound different?
Twotwo5 v twenty5 21
Both have same drivers and I suspect roughly similar volume?
Why could these not be compared?
Id much rather have the active pro than the hifi one.
Why don't you.arrange a home demo and tell us what you think?
I think it's only 3500 that's for speaker and amp?
How much would the hifi equivalent cost say with a naim super uniti?
Andrewjvt said:Can you name one manufacturer of passive and active models that agree with you or say their passive models are not inferior to the active?
I use the term outdated as in people's traditional way of thinking.
abacus said:A speaker is designed (Or should be) to turn electrical energy into mechanical energy as accurately as possible, and it is easier to design an active speaker (As the designer has full control over everything) for this then a passive one. (The active also allows controls to be incorporated to better integrate with the room WITHOUT causing any downsides of its own)
Most active speakers are designed for pro use, and therefore visually do not integrate well in a domestic environment, plus they also require more cabling for them to work, so while they can offer better quality sound than similar passives, they are not practical for all.
Apart from visually and cabling, you should not focus on either active or passive, but instead go to some live music venues and choose speakers that give close to this sound within your budget, (If you are going for sound accuracy) or if you just want something that sounds nice to your ears, (Most Hi-Fi users don’t seem interested in accuracy and authenticity) buy speakers that do just this.
Bill
I think one of the reasons for the differing opinions here may be the music we are thinking about. My reference is usually unamplified Orchestra, singer or grand piano. Yours may be an electronically created record that has no live equivalent. Another’s may be stadium rock. Another might be night club jazz, or a local pub band.Gazzip said:abacus said:A speaker is designed (Or should be) to turn electrical energy into mechanical energy as accurately as possible, and it is easier to design an active speaker (As the designer has full control over everything) for this then a passive one. (The active also allows controls to be incorporated to better integrate with the room WITHOUT causing any downsides of its own)
Bill
Just penned a long response to this but the site ate it. My main point was that pro studio monitors are not used in the final stages of mastering. Grotboxes, earbuds, car stereos and domestic hifi are the final medium used for studio listening, mastering and creating what the artist intended their audiences to hear. The mix is adjusted so it sounds good on these “inferior” mediums, so pushing that final recorded signal back through studio monitors in your home is not presenting how the music was supposed to sound. Quite far from it actually.
Bill
ellisdj said:Surely pro speakers are ugly on purpose - its costs a lot for a nice fiinish - save on that its cheaper to sell.
Noone wants to pay more in the pro world - they are there to make money not indulge in the love of it all
abacus said:Apart from visually and cabling, you should not focus on either active or passive, but instead go to some live music venues and choose speakers that give close to this sound within your budget...
Andrewjvt said:Gazzip said:abacus said:A speaker is designed (Or should be) to turn electrical energy into mechanical energy as accurately as possible, and it is easier to design an active speaker (As the designer has full control over everything) for this then a passive one. (The active also allows controls to be incorporated to better integrate with the room WITHOUT causing any downsides of its own)
Bill
All this until tested is only your theory. And unless all the normal 'hifi' perceptions are eliminated it's just an opinion.
Go listen to a few first
Like I've said - I'm not a PMC fan so maybe you.can tell me what's so different about the drivers on those models.
I can speak for ATC and apart from an s spec tweeter on the 50s upwards the drivers are the same and I've had a demo of.all the active range at ATC of the pro range and they set them up like a hifi in a typical.lounge and there is nothing near field compared to the hifi what so ever apart from the looks.
That goes for all the other studio monitors I've heard too.
Point is you don't have to be ridiculously close to listen to them properly.
My jbls sounded much better in my old lounge about 6mx 4m
My new lounge is tiny and they sound worse.
stereoman said:Well said about passives that they rather serve uncontrolled / wooly bass in comparison to actives. Even when actives are limited and clinical sounding, I find them really musical and spot on with sound. My next purchase will be actives.
Gazzip said:stereoman said:Well said about passives that they rather serve uncontrolled / wooly bass in comparison to actives. Even when actives are limited and clinical sounding, I find them really musical and spot on with sound. My next purchase will be actives.
This isn’t a debate about active vs passive. Plenty of those going on elsewhere... This is about the FR setup of studio pro monitors vs domestic hifi bookshelf speakers. I do however wholeheartedly agree with you that active speakers are better by design on many levels.
Gazzip said:Andrewjvt said:Gazzip said:abacus said:A speaker is designed (Or should be) to turn electrical energy into mechanical energy as accurately as possible, and it is easier to design an active speaker (As the designer has full control over everything) for this then a passive one. (The active also allows controls to be incorporated to better integrate with the room WITHOUT causing any downsides of its own)
Bill
It’s not just about drivers Andrew, especially with transmission line speakers where the tuning of the line will fundamentally alter the low/mid output.
Pro studio monitors tend to er towards a flat response because this is good sound to work with. Unfortunately it is not generally thought of as a great sound for relaxing and listening to. Not just my opinion but the opinion of most mixing engineers who set up venues and auditoriums where live audio is played. They will generally tip that flat response, lifting the lower frequencies so it produces a sound which is nice to listen to. This is known as a house curve. Many domestic hifi loudspeaker manufacturers work by the same principles and tune their products to boost the FR lows in the same way, giving them a more powerful sound.
I think that listening to music on pro studio monitors is a bit like viewing artwork under a very, very bright light. Yes you will see more detail, but does it add to the overall experience and is it what the artist intended you saw? I think not on both counts but it’s all about opinion.
CnoEvil said:abacus said:Apart from visually and cabling, you should not focus on either active or passive, but instead go to some live music venues and choose speakers that give close to this sound within your budget...
+1
This would always be my advice....though I would say, choose a system that does this.
Andrewjvt said:Gazzip said:Andrewjvt said:Gazzip said:abacus said:A speaker is designed (Or should be) to turn electrical energy into mechanical energy as accurately as possible, and it is easier to design an active speaker (As the designer has full control over everything) for this then a passive one. (The active also allows controls to be incorporated to better integrate with the room WITHOUT causing any downsides of its own)
Bill
but have you actually listened to a few? or is it how youd typically think it should be? i think you may be supprised
Ive a few demos arranged over the next few months so im going to add passive PMC v Active PMC if i can now. ill also contact them regards tunning
Andrewjvt said:That's why ATC (and dynaudio to less degree) are my choice. They can compete imo with any make/model at any cost imo
They have all the virtues of quality studio monitors but can be very good quality play back speakers as others have also noted. They don't have any difference in voicing or tuning.
As regards the cheaper monitors it's value for money and for very little cash can bring a few traditional hifi set ups to their knees.
I've also not noted the harsh listening on these cheap models.either that's why I recommend them. So far I've not heard any difference between studio or hifi except better bass control and being more accurate.
I was also surprised how good the cheap.ones sound and like you also thought they would not sound good in my mind on first purchase.
I'd be up for a studio monitor v passive hifi set up blind test. But for now I bid good day as I have a baby to clean
Andrewjvt said:ellisdj said:Surely pro speakers are ugly on purpose - its costs a lot for a nice fiinish - save on that its cheaper to sell.
It will look pretty for sure but not sound any different.
ellisdj said:Andrewjvt said:ellisdj said:Surely pro speakers are ugly on purpose - its costs a lot for a nice fiinish - save on that its cheaper to sell.
Quite the opposite was my thinking - if money is saved on the finish does that allow you to have more for your money inside the box at the same rrp? Is that why some prefer pro speakers to the hifi versions?
