NAS - advice, please
6th.replicant
292
Brain is overheating, please advise...Currently using a MacBook Pro (MBP) to play music files via an rDAC. If the material is 16-24bit/44.1kHz, it's streamed into an AirPort Express (AE) connected to the rDAC via TOSlink/optical.For 24bit/88-96kHz, the MBP is connected to the rDAC via USB.For 24bit/176-192kHz, the MBP is connected to the rDAC via a M2Tech HiFace/coax.To date, all's been fine. However, my MBP's HDD will soon be full.Is the solution a NAS? (A Synology DS211j looks tempting...)Will it be possible to stream 44.1kHz files into the AE or, in effect, will the NAS replace the AE? Will it be possible to send 24/176-192kHz files to the rDAC via the M2Tech HiFace/coax if the contents of my iTunes is on a NAS?If the contents of my MBP's iTunes is transferred to a NAS, will I be able to load/update an iPod from the MBP?And, assuming the NAS has sufficient disk capacity, will I be able to also use the NAS to backup my MBP's HDD?Thanks :)
Currently using a MacBook Pro (MBP) and iTunes to play music files via an rDAC.
To date, all's well. However, my MBP's HDD will soon be full.
If so, is it be possible to stream 44.1kHz files into the AE from the NAS?
Overdose
279
I don't know all of the answers to this but there are other forums out there that specialise in HDD hifi and are not so quiet as in here.
