- Aug 10, 2019
- 2,556
- 4
- 0
Hi all, Iv had my CD5x for a couple of months now and loving it. The only problem is that when I burn new CD-R's the Naim always displays "ERR" or error. With older CD-Rs iv burnt its normally error free and can play the whole CD trouble free. With a dozen or so newer CDs it comes up as error. Sometimes 1/10 times I select the track it plays. On other CDs I burn it can be 50% or higher, sometimes 99% trouble free. The Naim seems so sensitive to CD-R's even in mint condition. Though the OLDER CD-R I made some time ago a perfect. I use iTunes to Burn with an external drive. Iv used 2x speed and 8x speed for burning with the same results, and Imation/TDK brand CD-R which are average in NZ. I tried NERO to burn but my files are apple lossless and it didnt work. This is sooo fustrating is there anything I can try? Maybe its my CD drive, but iv tried the laptop internal and a external DVD writer 16x, with the same result. I was so convinced it was the Imation CD's but the TDKs were the same, and iv used older cds I burn with the Naim and they are fine. Only thing I can think of is its iTunes??? Its 7.2 version I think surely its not this? After It says "finalizing cd..." and takes ages, the cd DOESNT appear as an audio in iTunes unless you eject the CD. It used to pop up as audio after a few min even if you didnt eject the cd. This a problem or normal? Sorry this is long post, just so fustrating can only listen to older burn CD'Rs and new ones can be 90% no error, or 10%.....
