- Aug 12, 2008
- 33
- 0
- 0
I do appreciate your input Overdose. The problem is that it's impossible to demo ADM in Belgium. I would audition these speakers if I could because I absolutely see the benefits of such an approach.
Audiofoolius said:I do appreciate your input Overdose. The problem is that it's impossible to demo ADM in Belgium. I would audition these speakers if I could because I absolutely see the benefits of such an approach.
Overdose said:plastic penguin said:Overdose said:Whatever you decide, have fun and enjoy the music.
Not again, please. Just because you like active speakers it doesn't mean they are to everyone's taste.
The OP wouldn't know if they were to his taste as he clearly hasn't heard actives, much like many other naysayers it seems. My opinion is no less valid than any other so far and might actually be the perfect solution in this instance.
Maybe instead of displaying you negative bias, you could constructively advise the OP why active speakers and in particular, the ADM9s might not be ideal?
marou said:Yes, OD, please do tell us again why like ADMs.
You are being a bit of a nununana if you ask me.plastic penguin said:Overdose said:Audiofoolius said:Active speakers have a great price-performance ratio , but at this moment (as I already have a decent system) I am not really interested in that option. From what I have read about ADM I also fear that they might sound a little too analytical for my taste.
I'm not sure what you mean by 'analytical', but active speakers generally suffer from less distortion than passive speakers and in the case of monitors, are designed to reproduce the music as closley as possible to the recording. That's not to say that you'll find that a good thing, but they are not typically designed to have any inherent colouration, although design limitations mean that obviously some will exist.
Your initial post suggests that actives could be ideal for you. I understand that you have a system that you are happy with, but you intimated replacing speakers and then possibly having to upgrade the amp. For the same overall outlay (taking into consideration any residual value of existing kit) you could achieve the same result via actives, possibly even with a sub. The ADMs are my second set of active speakers, they might well be my last.
Overdose said:This is starting to veer off topic (sorry OP), but I feel that I need to qualify why I (and others probably) recommend and rate the ADMs so much.
BigH said:I have not heard the 685s but I have heard the CM1s which are similar but have more bass than the 685s I
Audiofoolius said:Thanks for the interesting remarks!
I am not looking for speakers that have more bass than the 685's, just better quality.
poldo said:Hi Audiofoolius,
I swapped my PMC Twenty 22 for the AVI ADM 9.1 RS speakers, no regrets. I like the ADM more then the expensive PMC's. I live in Holland by the way, Rotterdam.
Maybe you could ask the AVI dealer in Holland if you can send them back if you don't like them?
the record spot said:Overdose said:This is starting to veer off topic (sorry OP), but I feel that I need to qualify why I (and others probably) recommend and rate the ADMs so much.
You didn't. A link to a relevant thread would've been fine, of which there are several. The ADMs are unsuitable for reasons of the OP can't readily access any.
The ADMs are ust one of the active speakers now available, they no longer have the market to themselves. Also bear in mind that all active speakers do not sound the same, so one person's accurate is another person's unlistenableAudiofoolius said:I do appreciate your input Overdose. The problem is that it's impossible to demo ADM in Belgium. I would audition these speakers if I could because I absolutely see the benefits of such an approach.
the record spot said:OD: If you'd bothered to read my post, you'd have seen that I snipped all but the first two lines of yours. I stand by it.
And to point out, for the nth time, I've said on many occasions what my views are on the products both current and past of AVI and it's a matter of record on here. If you can find where I've decried them (the ADM9), am biased against them for the product they are, or suchlike, then please point it out. If you do, can you also point out the many times where I have talked them up. Balance and all.
I'm not obsessive about the product at all, far from it in fact, so again you're shy of the mark. And as for not commenting on a post, well, you put it up on an open forum. My comment was based on your feeling "the need" to qualify why you like them. You didn't need to. Rather straightforward.
And I'll reserve the right to respond to a post where I see fit against your right to post whatever you choose in the first place. That's freedom of speech, sorry if it rains on your parade.
SolarGlider said:Well, to answer the original question. I don't think a Nait 5i will have any problem powering the KEF's. I've heard the Nait 5i on a full size monitor gold speaker and it could get it to painful volumes.
It's always nice to talk about combo's with speakers but always try to hear the match first.
Things can seem perfect in your head while the actual execution may leave much to be desired for.
Audiofoolius said:Active speakers are a bit too expensive for me at the moment. I can just about stretch my budget to buy the KEF's.I don't plan to buy a new amp in the next couple of years.![]()
chebby said:Audiofoolius said:Active speakers are a bit too expensive for me at the moment. I can just about stretch my budget to buy the KEF's.I don't plan to buy a new amp in the next couple of years.![]()
The idea is that you sell the amp (I got £580 for my Nait 5i two years ago) and add the money to your speaker budget. That should - just about - get you the latest version ADM9s which have their own amps, DAC and remote controlled pre-amp all built in.
