NAD C320 amp is playing up!
Hi guys my brother has just pointed out to me that every time he tries to play some music, the amp will switch itself off, is this the end of the road for the amp?
If so can anyone recommend me a really really cheap amp that i might be able to get second hand?
One - Don't turn the amp past the 12 o'clock position.
Two - Check the connections to the speakers aren't short circuiting.
Three - If the problem persists, turn off the "Soft Clipping" system via the switch at the back, and try it again, but please be careful when you turn it up as it turns off the overpower protection and it will blow speakers very easily!
four - check the cooling slots are not obstructed.
Thanks pal i revisited the connections and it was like you said, a short circuit being created via the cables.
hi fi newbie:Thanks pal i revisited the connections and it was like you said, a short circuit being created via the cables.
Cool - no problems then! Tell your bro enjoy such a superb amp!
