I picked up a NAD 312 today, cosmetically it looks great, it was going for next to nothing so I took it untested. It has a gremlin that's a little baffling. Hoping if someone has experienced this before they can offer some insight.
The left channel is louder pulling the center image quite noticeably to the left. I had to adjust the balance to 3 o'clock before it straightened out. When the volume is all the way down I can still hear a very soft signal coming through only the right. I switched out speakers, cables, source and changed inputs and it's definitely the amp.
Next I started looking at the pre/main connections. I swapped the pre/main jumpers around, no change. I then replaced the jumpers with RCA cables, no change. This is where things got weird. I used the RCA cables to cross channels PreL to MainR and PreR to MainL... and now it's perfectly balanced and center!
That doesn't make sense!!! I would have expected it to pull center off in the opposite direction.
With my inputs also LR swapped everything is perfect. I would however like to get it working as designed at some stage, so if anyone has any ideas, please shout.
