My system updated
striple
16
Hi all
Pictures of my system updated
Upgrades are
Yamaha dspax757se replaced with Denon avr 1910 (very happy with)
Dynaudio Audience 40’s fronts replaced with B&W 685’S
Dynaudio Audience 42c centre replaced with B&W HTM62
Overall very happy with present setup next upgrade possibly blu-ray player
Nice and neat. Your left and right speakers are angled funny though - is that due to the sitting position in the lounge?
Your BD35 is a pretty good player. An upgrade needs to be significantly better to justify the outlay - along the lines of a Sony BDP-S760, Pioneer BDP-LX52 or Denon DVD-2500BT.
Hi Evilwolf
In answer to you question,yes sitting position is off to right of picture not ideal but there you go.
I was thinking on the lines of the Pioneer lx52 or maybe the Denon as prices keep falling.
Panasonic are also bringing out new line in the spring ,quick loading times also.
Get the screen wall mounted, and the center up onto the current screens position. This should give a much better spread of sound across the front three channels. Will look even better too and symmetrical.
Hi, very nice system there, I like how you have spaced out your speaker's and the positioning.
Nice.
Hi paul
Have toyed with the idea of wall mounting the screen,but if i did i would probably put it above fireplace in center of room, the only trouble with that idea is it's a bit high for viewing.we also have the tv toed to right as speakers are which aslo would cause issues with viewing.
thanks
Like how neat it looks , all the cables hidden and a nice spacious cabinet. Was wondering is that the biggest tv your room can accomodate, 42" wall mounted would look very nice And if your centre went on top it would give you greater soundstage, also a games console would fit in the spare space.
Hi Lobby
I would wall mount but it's just the wrong place to do so.
When we bought the TV, we upgraded from a 32 inch CRT so we thought the 37 inch would be plenty big enough. In hindsight we could easily have accommodated 42 inch - 46 inch.just going to wait until lcd,led or plasma settle out and upgrade in the near future.
Have a xbox360 on a 24" pc monitor upstairs in spare room at the moment !!
