My JBL Xtreme bluetooth speaker has me worried?
Feb 9, 2016
I recently bought a JBL Xtreme Bluetooth speaker. Though I am extremely happy with it I just have one concern. I have a kid at home. And though I make sure when the speaker is powered on it is out of reach for him or anybody else, recently the speaker was powered off and charging when my kid pressed the bass radiator opening on one side a few times out of curiosity. I later on powered on the speaker and it works fine without any issues with sound and there are no signs of any physical damage. How can I be sure that its perfectly alright and how durable are the bass radiator openings on both sides. Please advice !
Here is the product link for reference: http://in.jbl.com/product-detail-new-jbl-in/jbl-xtreme-blue.html
No comments usually means nobody owns or is familiar with your speaker
Should be fine. If you hear no issues then don't worry. Bass drivers are usually pretty hardy and as these are exposed id imagine they take such contact into account in the design
