I decided to have a go at making a set of interconnects myself. I was trying to do it on the cheap so I got an old set old leads out and took the plugs off and was going to use some 75 ohm coax to make a new set. I have never used a soldering iron before but I thought what the hell. Well it was a total disaster, I had to hold the iron on too long to melt the solder and ended up melting the plastic spacers in the plug.[😡]
They say you should never blame your tools well I did. So off I pop to maplin to get a new soldering iron.
Got a good price too, £14.99 reduced from £30. While I was there I needed some new plugs and I saw some cable I liked the look of so got 2m of that, total cost of plugs and lead just short of £20.
Right the, time to start. I stripped the first end and soldered the inner core.
This is when I realised, the plugs I'd bought only soldered on the inner core and not the shield, the shield clamped when it's all screwed together. I'm learning as I go along.
There we go the first inner part of plug soldered on.
The first completed end. Only 3 more to go.
All done now, just had to check them now with my multi meter to make sure the connections are ok with no shorts. I must be honest I now have a great feeling of satisfaction, and I do think they look really good.[😀]
Now the moment of truth, how do they sound. I made these to replace a cheap set that I was using and have been meaning to replace for quite a while. Whilst connecting them up I hit a snag, the plugs are that large in diameter they touch.
OOOH NO!! After a bit of ranting the OH came up with a good idea.
It's amazing what you can do with a bit of cardboard. This is only going to be a temp' solution as I'll try to get some slimmer plugs.
Finaly time to switch on and try them out. Well was I pleasantly surprised, they sounded surprisingly good, good strong bass, nice mids and treble, quite smooth not bright sounding at all (which I hate). I then disconnected them to do a comparison with my other IC's which are Straight Wire Symphonys, I purchased these approx 18 yrs ago at £50 a pair. Plugged them into my cd players 2nd set of outputs so I could play a cd and just switch inputs on my amp and get an immediate comparison.
I was amazed they sounded virtually identical, apart from the ones I made were ever so slightly a bit more forward in the upper bass. I'm so impressed with the results I'm going to start experimenting making more from diff' leads etc to compare. There is lots of information to be found through Google.
Another important lesson I learned, DON'T TOUCH SOLDERING IRONS, THEY'RE VERY HOT [:'(][:'(]
