MS Mezzo 2 & Cyrus 6vs2- biwire or not to biwire, that is the question
knacker
64
Guys and gals, just picked up the above as it sounded great when demoed in my house. The demo kit had single wire and just wondered if it would be worth bi wiring. If so, what cables should I be looking at- the longest length will be approx 4-5m- subject to cable management.
Quick answer is it's unlikely to make any difference whatsoever. There are many threads if you do a search.
You could try the f connection, which basically connects the same speaker wire to both top and bottom posts. Saves you heaps of money.
Oooh, there's a tip and a half
never even noticed that
