- Aug 10, 2019
- 2,556
- 4
- 0
Hi all,
I am just about to buy a Marantz MCR603 and a single pair of Monitor Audio BX2s. I have heard that the Marantz has four ports so you can bi-wire the speakers if you are only using one pair.
By doing this, will the sound be significantly improved, or am I better off just running a single length of cable? Is there actually much difference?
Secondly, and excuse what is a very newbie question, but how exactly do you connect if you are biamping. Is it just a case of buying twice as much cable and running two sets of cables from the Marantz to the speakers. Do the BX2s have four ports on the back to do this?
Any help much appreciated. I'm looking to buy asap so just need to know how much cable to get.
