MPC - HC
I guessed that you might know. If not.
A video player that you can use MadVR. It's free and has a 64Bit version, but is Windows only. I use it for the same reason you might use Foobar2000, simple GUI, very tweakable, good subtitle support and with MadVR, best in the industry video.
Generally these updates fix bugs, and the list is huge, but no worse than any other program. It's the commitment thats amazing for free software. I would recommend for ease of use.
Highlights include there EVR renderer, 10Bit in and out and lots of other video tweaks,
Whilst I have a problem with the audio SQ, that is an opinion.
