Hello David! Thx for your insight.
When you say it doesn't sound how they expected it to sound, what should be expected ?
I m not interested in the latest features most commercial brands usually give us, like network or iphone connections. I need an AV very good with music that can handle the RX8 (4ohm speakers) and proficient with movies.
I have a SR7005 and it does not do the job. IMHO it does not have the power needed to drive the RX8s, however, it is very good with the movies.
The Rotel is a little bit cheaper than the Primare, 400 pounds cheaper. I will need to change the Video board of the Primare, to the latest version from the SPA23 due to some annoyances of the old version, specially the configuration menus, which are only available through the SVIDEO or Component conns and not from HDMI.
What kind of sound will i get from these amps with my speakers ? Will it be warm, balanced, bright like the Yamahas and Pioneers usually give ? I really really don t like at all harsh, bright, or "in your face" kinds, so those i will need to avoid. That´s where i will need your help
P.S. I did some auditions with the RSX1550 (class A/B) CM8 and Primare SPA22 HD with MAs GX50. I liked the Primare/GX but i really loved the RSX1550/CM8.
