SteveR750 said:No amount of room adjustment will make a crap amp sound good, but it might make a good amp sound like it should do. I haven't heard anything other than cheap budget amps that sounded better with tone controls, and all that had them (NAD 3130, 352, CA azur 640) were worse off with them deployed. I'm not against tonal changes, just that doing it in analogue doesn't make for great hi fi. Doing it in 64 bit digital is another thing altogether of course.
Sorry, but I disagree that a £300 receiver is even close to the best £700+ amps (Roksan, Naim etc) tone controls or not. Just my opinion of course 🙂
Thompsonuxb said:SteveR750 said:No amount of room adjustment will make a crap amp sound good, but it might make a good amp sound like it should do. I haven't heard anything other than cheap budget amps that sounded better with tone controls, and all that had them (NAD 3130, 352, CA azur 640) were worse off with them deployed. I'm not against tonal changes, just that doing it in analogue doesn't make for great hi fi. Doing it in 64 bit digital is another thing altogether of course.
sorry forgot to quote, this is the post i'm responding to.....
oh, did I mention I have the bass boost button on, well I do.
shaunj_uk said:So, has anyone actually got any Monitor Audio RX2's? If so, what do you think of them in terms of bass etc. Also, curious about the Rega RS1's?
Shaun
shaunj_uk said:Hi,
I currently have a Roksan K2 amplifier, Rega Apollo cd player and Monitor Audio RS6 floorstanders. I am looking to change the Monitor Audio's, just feel like trying standmounts, as the floorstanders seem bit too much for my room which is roughly 4m x 3m.
I have been looking at the Monitor Audio RX2's, they seem to be quite highly regarded, but will the bass on them be too much for my size room, as I dont like it too overpowering? I listen mostly to rock music, at moderate levels, but would like the speakers to go higher if needed without a struggle >) , hence me looking at the RX2's. My budget is around £450 new or second hand.
Any help or suggestions would be gratefully accepted.
Kind Regards
Shaun
plastic penguin said:*Rega make some fantastic equipment, which will match and better price-compatible standmounters. I'm sure they are fabulous little speakers. However, the key word is "little". As Sizzers has stated they are compromised, in the bass area, due their size.
plastic penguin said:I'm sure they are fabulous little speakers...
chebby said:plastic penguin said:*Rega make some fantastic equipment, which will match and better price-compatible standmounters. I'm sure they are fabulous little speakers. However, the key word is "little". As Sizzers has stated they are compromised, in the bass area, due their size.
Nice catch after dismissing the Rega RS1s as 'thin and insubstantial'.
I have heard them on the end of a Naim CD5 XS/Nait XS system and they sounded fantastic.
So you haven't actually heard them?
WHF? Have reviewed many Rega products, many of those have received 5 star reviews, some have received WHF? awards...stevebrock said:i am very surprised WHF have not reviewed the RS1' without being nical WHF get no advertising revenue at all from Rega but lots from Cyrus
shaunj_uk said:Hi,
Think I will leave the RX2's, seems like they will be too much of the same as the RS6's. Has anyone heard the Roksan K2 TR5 speakers, or Proac 110's? Could be out of these two.
Shaun
plastic penguin said:shaunj_uk said:Hi,
Shaun
Roksan speakers could/should be ideal, however you'll need to strike a balance - I believe - when it comes to bass. http://www.whathifi.com/review/roksan-kandy-k2-tr-5
Whatever standmouter you choose won't give you the depth, but do compensate in the areas of detail and precision...
I know from personal experience on paper standmouters seem ideal, but in reality the added bass of the RS6 does give the presentation an added dimension.
My current favs are Totem Arros: They are a titchy floorstander, same height as the RS6s... around half the width and depth. You don't get the bloated sound of the RS6s, replaced by a tighter, crisper presentation, and they bang harder than the average standmounter. They do major in pin-point imaging and soundstage.
moon said:these look in better nic
http://www.ebay.co.uk/itm/Totem-Arro-Floorstanding-Speakers-Preowned-/190720220996?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item2c67cf9f44#ht_4754wt_922
might fit your decor
plastic penguin said:moon said:these look in better nic
Those ones have been on ebay for ages - no-one wants them. They have a dodgy base.
Would love a pair but because of their narrow dimensions, you'd only have to sneeze and they'll topple.
moon said:...or pet.
moon said:plastic penguin said:moon said:these look in better nic
not kid friendly. or pet.
