Mission MX S as desktop speakers
rab9090
39
Hello all,
I'm looking at getting some sort of set up for the desktop. Just now I'm looking at getting a small amp, like the NuForce Icon, and some speakers that are small enough for the desk. I've been looking at the active speaker options too, however I would like to get some opinions on the Mission MX S with NuForce amp combo. Has anyone gone for this sort of set up instead of actives?
Thanks for any comments.
If this is for the computer I think you will be better off with actives I posted a similar question in the computer branch: http://www.whathifi.com/forum/computer-based-media/improving-computer-sound
Thanks for thr reply. I'm still leaning towards actives too, I thought an amp and passives might be cheaper but it seems to be about the same.
HAving looked into a bit more there are loads to choose from. If you want a speaker and amp then have a look at this:
Teufel Concept B 200 USB
