Media Player for Vista (Video) What do you use please?
mattjax05
230
Can anyone recommend a good media player for watching video files (not DVD or Blu Ray) on laptop and also streaming downloaded video to the tv via HDMI. I have Media Monkey for music and just downloaded GOM Player to test (seems ok and has most encoders pre-installed) Also have WMP 11 but went to play an AVI file and it's not supported so I guess it needs encoders.
Thanks, Matt.
Hm. Windows media player supports AVI files generally, but you can never be 100% sure what type of video is stored in the AVI container. You might want to get something like gspot to check your files...
JohnDuncan:Hm. Windows media player supports AVI files generally, but you can never be 100% sure what type of video is stored in the AVI container. You might want to get something like gspot to check your files...
Ah didn't realise AVI was a container format, cheers. Is WMP a good chioce? Have you heard of GOM? So many choices......
Haven't heard of GOM, no. I find WMP perfectly fine tbh, including (with a registry tweak) ripped DVDs*
* for research purposes - do not try this at home
aliEnRIK:
I use the 'klite codec pack'
Plays 99% of all types of movie and music files
Excellent thank you, will stick with WMP.
I use VLC media player.Plays evrything you throw at it and I find it quicker than WMP.
bobbyg81:I use VLC media player.Plays evrything you throw at it and I find it quicker than WMP.
No player plays everything (Including VLC). But sure, Its a good decent player
