may i know the last marantz pm with lateral metal frontal panels?
Drugo
24
hi
i remember i had for a while a marantz pm made in japan with metal frontal panels
i own a Marantz PM 8005 but the frontal panels are in plastic
do you remember the last model pm with metal panels?
i put 2 arrows to let you know what i mean for frontal panels
thanks
Hi, Marantz is still producing several amps with metal front, but they are reference amps today. Like Model 10 or PM 10 and PM 12 before. For cheaper Matantz models I will not put my hand into the fire. And yes anything made from proper metal is expensive. I hate those plasticky "tofu" looking things as well.
Cost wise I can see why they might have done it but it would not factor in to my selection of an amplifier sound wise
hi
i remember was a pm with 4 number , 10 years old give o take
i would like to know the last pm with 4 number with the left and right metal panels
hi
thanks
I think it depends on the price point. I seem to remember those side pieces always being plastic. The previous generation starting with the PM4000 had a flat single front panel, they started out as aluminium, but moved to plastic on the 4200 and 4400, but stuck with metal on the 7200 and 8200.
hi
a friend of mine owns a marantz like the picture but with the lateral panels in metal ,it's give o take 10 years ago
do you mean all the marantz with the lateral panels are in plastic?
thanks
