toyota man
- Apr 22, 2009
- 79
- 0
- 0
dumbledore said:It looks like you need to work out the exact impedance characteristic of your Dali's. It obviously they are hard for the amplifier. However out of 4 one may exhibit very bas impedance causing the amp to go into protection. So maybe be there is a case of fixing the culprit speaker. If hopefully all exhibit good impedance then you cheapest bet to go for two amp configuration with the Dali's impedance not droping anywhere below 3ohms. If you want one amp configuration you will need to go for some essoteric amplifiers that are far to expensive. Your current yamaha appears to drive the Dal's because it may not have a protection circuit that is effective. However, when you drive the Dali's hard the amplifier will most likely sound stressed. Then you could try to connect your speaker in series then you would not have any issues with protection.
Mooly said:Speakers in series is a no no for quality as they interact electrically.
I don't know what it would be like in practice but the Marantz Pearl Lite squeaks in at £20 over the 600 mark and is reputed to be a sonic bargain. I have the Pearl Lite SACD and its stunning in every way.
You see, with the greatest respect, no amplifier in your price range is going to say that it will drive two pairs of 4 ohm speakers but, in real terms many amps will. You need a dealer that will let you try at home.
BigH said:I have read elsewhere that the
HARMAN KARDON HK980
Is a powerful amp. that can handle difficult loads, think you can get these still for around £250 - £290, it is fairly old now but maybe what you need.
GCE said:For me Yam AS 500 has plenty of details and a magical horizontal image, but a little bright for my taste ( I lived with it for 5 days...);
with his smart loudness you can have good sound at very low vol (in night time); have a test in shop or, better :dance: , at home...
dumbledore said:If an amplifier makes a speaker sound loud that you need to protect your ears this is mostly caused by the amplifier starting distorting badly not because the amplifier is powerful. As your yamaha is only 60W this could be the case. A powerful amplifier will cause the speaker to be stressed as the speaker will start distorting at high power drives. You should be able to differentiate between mechanical distortion caused by overdriven speaker and distortion caused by a weak amplifier that runs out of current and voltage by clipping the signal. Is possible that the Marantz has got a oversensitive protection system that is sensitive to any distorsion and shuts down the amp. The Yamaha protection system if is working does not shut down the amp, but probably just limits the curent delivery to protect the amplifier. Unfortunatelly a nasty protection system like this will not protect speakers especially the tweeters. I do recommend since you have many amplifiers at hand to drive each pair of Dali's by different amplifier. This should give you far better result then driving two pairs with one amp. But then is possible the Maratz amp you tested is not oversensitive but is just faulty. Ideally you should try another one before you can condemn the amp to be oversensitive or your Dali's to be a difficult load. The Dali's I understand although they are 4 ohms rated they are easy load, so if they are proving difficult I would check them. A easy way to check them is with a voltmeter. The DC resistance should be around 3-4 ohms. Any less and you should be suspitious. As you have 4 speakers, they should all measure the same, any one measuring different again you should suspitious.
BigH said:I find with reasonable hifi you don't need to have it so loud.
One thing about 2 pairs of speakers there are 2 ways of wiring them, years ago I had 4 speakers and I wired them in series, ie 1 lead from amp to 1st speaker and then onto the 2nd speaker and same on the other channel, is that not a possibility, I understood that was the same resistance as one set of speakers?
lovemusic said:Hi Lovemusic you should change your name to Love Loud Music 😉 😉BigH said:I find with reasonable hifi you don't need to have it so loud.
Thanks, I know what you are saying about loud music, I just like loud music sometimes, well most of the time actually lol. Wiring the speakers in series is a possibility but we thought we would loose clarity.
