Forget about the B&W 606 s2 the highs are there weakest link and can easily give listening fattigue
I still very happy with my Mackie MR624 (active studio monitors)
Yes sure, i can alwas do that. But there, i get a single opinion. I would like to hear other peoples thoughts.Whatever we might suggest, it's best if you go to a dealer and audition for yourself....
Do you think they can fill my room?Forget about the B&W 606 s2 the highs are there weakest link and can easily give listening fattigue
that's a very good price. For that money I would get them and give them a try, if they don't work well them on.Hi, i have been offered a Pair of almost new Dali Oberon 5 for 220 Euros. Should I give them a try or do you think my "Problem" is more on the amplifier-Side?
Yes, this is the main question. I don't want just to buy a pair of speakers at a good price. It is always an effort to get them, set them up and eventually re-sell them. So, my question is, if i can expect an improvment at low volume with these speakers and my marantz.I am unsure as to how well your amp will drive them
Thanks, very interesting. unfortunately, It seems that they are not available in switzerland.I would look at buying a used pair of PMC DB1i or floor standing GB1i.
When Andrew Everard had the earlier incarnation 603s on home demo he tried with his GB1is & was delighted how well it performed. So it might be worthwhile for the OP to go & listen to PMCs newer range Twenty
Any speaker with 8 ohms & 87db upwards should be fine. It can't be less gutsy than the earlier models. That's why I mentioned older PMCs. I drove a set of DB1s with my 40 watt Arcam without any issue.For Judiths budget I would suggest these if standmounts are required, or it's floorstanding cousin....
Icon Audio MFV2 Speakers
Icon Audio MFV2 Speakers Available in a high quality walnut finish. Nearly all of the hi fi speakers available today are designed for powerful transistor amplifiers, this means the speakers are very power hungry and can be a difficult load for valve amplifiers. This is especially true of smaller...www.analogueseduction.net![]()
Icon Audio MFV 3 MkII Super Speakers (Pair)
Icon Audio designed the MFV3 MkII Super floorstanding speakers are the biggest in the range, piano black floorstanding speakers capable of filling a large room with beautiful golden sound from as little as 10 watts. As high sensitivity speakers, they can be matched with low to medium power valve...www.audioaffair.co.uk
Some of the most amplifier friendly speakers I know.
Oh, the MV2 seem to meet my expectations pretty well🙂For Judiths budget I would suggest these if standmounts are required, or it's floorstanding cousin....
Thanks for the recommendation of a set.Judith, if you can reserve and slightly stretch your 1500 to 2000 Euros, and you like Marantz, I would look at the PM7000N and the Focal Chora 826 AIears suggested.
You could also consider the much cheaper Q Acoustics 3050i, which would then be within your stated budget.
BTW I don't recall which subwoofer you have?
Here's a Swiss retailer https://www.mueller-spring.ch/. They seem large and established so you may be familiar. Maybe you can shop around.
Hi, the qacoustics are also often recommended with the m-cr 611. do you think they wold be an improvement at low levels over my dali zensor 3?Thanks for the recommendation of a set.
I know müller spring and they are not far away from me. I have planned a visit there.
Personally I do not.Hi, the qacoustics are also often recommended with the m-cr 611. do you think they wold be an improvement at low levels over my dali zensor 3?
