Matthew... if you want to step up a notch or 2 on the CDP, I have heard that the Musical Fidelity A3.5 Unsampling CD Player is pretty good, but expect to pay approx £400 for a used one in good condition ...
I have never heard one
I am not sure how it would sound on your new system, but am sure that some people with more experience will comment
Here is one on ebay in good condition with a buy it now of £399.99 (ebay item 250518374663 ... you may find one cheaper
if you are interested in spending this amount on a used CDP, first get some more comments/info from people who are familiar with this item ...
here are some specs as found on the net (weighs a lot ... nearly 11kg ):
DAC architecture - 24 bit Delta-Sigma (Bitstream) Dual differential 8x oversampling
Disc mechanism - Philips
Upsampling - 96kHz
Frequency response 10Hz to 20kHz +0 / -0.2dB
Signal / noise ratio > 115dB "A" weighted
Total harmonic distortion < 0.006% 10Hz to 20kHz
Total correlated jitter < 170 pS
Channel separation > 100dB 20Hz to 20kHz
Linearity < 0.2dB down to -90dB
Audio output at digital 0dB level - 2.14VRMS at 1kHz nominal
Analog output 1 pair RCA connectors
Analog output impedance - 50 Ohms
Digital outputs - 1 optical (Toslink), 1 S/PDIF (RCA connector)
Power requirements 100 / 115 / 230V AC 50 / 60Hz (factory preset at 220V)
15 Watts
Dimensions (approximate)
440mm, 17.3 inches wide
100mm, 3.9 inches high including feet
395mm, 15.6 inches deep including terminals
Weight - 10.8 kg, 22.8 lbs unit only, un-boxed
15.5 kg, 34.2 lbs in shipping carton
Upsampling - 96kHz
15 Watts
