Majority Quadriga
thebluecafe
14
Has anybody heard the Majority Quadriga? Saw an article on what Hi-Fi mentioning it but would be interested in hearing how it sounds?
Looking at the apparent lack of dealers it would seem demoing one might prove difficult unless you buy and return if not satisfied.
Yeah, them and dozens of other brands. Also just because they have the brand on a said dealer website there's no guarantee they hold stocks.
Unilet are Leema dealers yet the only models they stock is the Elements, Tucana models.
Afraid I haven't, but having quickly looked at it, not sure what advantages it gives over a Sonos product (unless you need / want the extra functionality such as CD / broadcast radio).
Probably something to do with added function and cost...... And yes, some people do require DAB radio and / or CD function so its nothing like a Sonus product
For the big price of £249, I was expecting a bit more fanciness when it came to the UI display and the modern tech elements, however, as a whole package, £249 seems reasonable and the screen does do the job.
I would say ridiculously cheap. However, I would only consider it if I could somehow get 5 years warranty.
Anyone considering this unit should also check for "Toshiba Laptop 75W 15V 5A" power adapter to replace the power adapter offered with this unit. It is not the double power capacity that is important, it is size. The larger adapter has a larger capacitor for power reserves, which is necessary to actually operate at more than a few watts.
That's why laptops have them even thought they do not need to drive 6" woofers.
I bought a majority radio from Amazon for my daughter. I must say I'm surprised at how good the sound quality is, plus build quality and features are also very good. I can well imagine that the model you are looking at will be even better, so order it from Amazon, if it doesn't meet your requirements just return it.
RSL makes and sells excellent subwoofers in an awesome price range. A 10” and 400 Watt for $450
