Magnepan 3.7i Emotiva SA 250
Feb 14, 2016
Doess anyone have experience on amplifiers with magnepan 3.7i - the list of consideration so far is.....
Sanders Magtech
Audio gd - master 3
Emotiva SA - 250
I realise they are hungry for power but budget is also an issue! Emotiva also do the xpa -1 with 1000 w into 4 ohm..........
Just want an opinion before shelling out for 500 wpc (4 ohm) and finding its not enough !
Sanders Magtech
Audio gd - master 3
Emotiva SA - 250
Hi Paul and welcome.
That's a serious set-up you're building there! I'm not familiar with the amps you're considering (you're in the States, right?), but I guess the Magtech's 900 W into 4 Ohm would be a great place to start. And Mr. Sanders gives you a free 30-day trial (including the return shipping IIRC), so not much of a risk. In case it would prove lacking in the long run (not likely IMO), you can add a second unit, and go for 2000 W/4 Ohm! *shok*
If budget is a little tighter, and 500 W/4 Ohm can do, you could also consider a pair of Hypex NC500 monoblocks (Acoustic Imagery, or Nord [that's Colin, a fellow forumite]). Price per watt will be similar to the Magtech's, probably better.
Keep us posted on the result, anyway. I'm most interested in what you end up with!
I can vouch for the ability of the Magtech to drive difficult loads. I use one with my Martin Logan Montis, which has horribly low impedance at high frequencies. The Magtech does a great job: it produces a huge, immersive, 3D sound with lovely smooth treble. I have the system in a room 5.25 x 5.25m, and I do play quite loud on occasions, mainly symphonic and opera. Even at very high volumes in my room, there's no hint of distortion.
Buy with confidence.
*good*
Thanks - in UK but happy to try esoteric stuff!
My good friend runs 2 sanders magtechs into sanders electrostatics - very impressive but at £ 4000 + each even 1 is relatively expensive - ive read good things (and bad) about the emotiva stuff and wanted to know if people had experience with it as i am struggling to find a better buy ( 1$ per watt) but will also look into your recommendation
OK, so you've heard what the Magtechs are capable of.
I'm afraid I know nothing about Emotiva, so I can't help you there. If the specs look good, then maybe you can buy with confidence. Dunno.
With Maggies, I'd be thinking about Class D amps, such as DocG suggested. You could get two mighty monoblocs for less than £2K.
Or a dual mono for just under a grand: look here!
As for the Emotiva: is there a dealer in the 'hood? Home demo feasible?
PS: we need more people with exotic taste here to cheer the place up a little! *wink*
Ah yes, much cheaper than I thought. *acute*
Yes, almost makes me want to start all over again and go more exotic. *crazy*
Yeah! You know you want to! Who would stop you? Oh, let me guess...
Paul Carroll said:
Those Nord amps look very good vfm but they will open the ususal debate of Class D vs Class A!
They're not class D, they're Hypex Ncore (wire with gain, and all that...)! *wink*
BTW, what front-end do you use, Paul? (Just curious)
I haven't been fortunate to hear neither the Emotiva nor Sanders, but have read very good things about both... if it were me, I would probably go with the Sanders as I do trust Matt49's judgement, not to mention sound advice from Doc.
Great to have a bit of exotica on the site at last... more please.
Mac
www.macsmusic.blogbubble.net
