m&k ss150 speakers
jokerpaulonline
54
I have just purchased a set of mk1 M&k ss150 speakers and wondered if someone could tell me what terminals i need to put the speaker cables to have them as a dipole speaker. I have removed the bridge terminal between 3 & 4 .
http://web.archive.org/web/20040725173734/www.mksound.com/pdf/user_manuals/user_mains/ss150thx-man.pdf
try here mate, theirs all you need to know about M&K`s
cheers Allan @ Ideal AV
Link is working.
Have you set your browser up with a PDF reader Adobe acrobat for example.
Firefox has it as a plugin and when enabled will open up the Pdf in the browser.
The link is the operations manual for the MK SS150 which basically says to remove the bridge terminal between 3 & 4 for Dipole operation as you have done...... but there is more usefull info in the manuel you need to sort your browser out so you can see it.
