M-Audio AV-40's vs. Behringer MS-40
Since this is such highly regarded website with many experienced audiophiles (without a doubt) I decided to ask the same question I did on Head-Fi.
Fair enough, which one is the best? If you know better ones (up to £100-150 max) then suggest away.
Either of these will be used with a computer (but if you suggest other speakers, it doesn't matter if they're passive but be careful about the price) and will mostly be used for Music (70%), Movies (25%) and Games (5%) but music is definitely the most important. I mainly listen to a lot of Trance, and very, very little of anything else (and that is mostly other styles of Dance e.g. House, Electro). Bass isn't really important but I still prefer quite bassy speakers.
I can also get a pair of speakers from Richer Sound since I have one locally but they often have very little stuff. And if someone suggests passive speakers then I'll have to get a power amp too so mind that I have to fit all that in the budget.
Cheers, Atis
