- Aug 10, 2019
- 2,556
- 4
- 0
I've also posted this on AVforums so if you've read it there, apologies!
I'm looking for an amp which must be less than 320mm in depth (give or take 10mm) after adding plugs etc. It's a shelf-restriction, don't ask
Other info:
· It must have a remote.
· Budget = upto £400. I'm upgrading from an Arcam Alpha 1(!) which neither has a remote or the power I'd like.
NB: No speakers yet but looking at BX2s with interest. Need to be front-ported, sit on similar sized shelves with a 370mm max height. Dimensions of BX2s are: 350 x 185 x 255 mm. But that's another story/thread!
So far I've found:
1) NAD 326BEE: 435 x 100 x 286mm) which will just about fit, I reckon. I have no particular experience of NAD ampsthough the plastic front and looks put me off a little.
2) NAD C352 (Second hand): 435 x 100 x 290mm
Can anyone add to this list easily? Really appreciate it.
Other info:
So far I've found:
