lockdown boredom faffing
bigfish786
Moderator
Jan 29, 2013
396
210
19,270
got bored today, so i decided to strip down and clean the turntable, clean the bearing, replace the bearing oil, and for some crazy reason.... i replaced all the little gel pads between the glass shelves and the Atacama metal rack.
no, i'm not going to do any "lifting a veil" or "night and day" posts.. but everything looks nice and shiny again.
very therapeutic.
Something I have been meaning to do for some time with my turntable. Was going to leave it until I got the heavy platter upgrade but that may be put off for a good while as I haven't been able to return to work so funds are a tad low
Gray
very therapeutic.
They look like the door buffers I've used all over the place (though never to buffer doors :))
I'm on my second batch of 50. Perfect between speakers and stands.
bigfish786
Moderator
Jan 29, 2013
396
210
19,270
yeah, i think that's what they are for (furniture).
work a treat, the original ones were very flat, and there weren't that many on there really.
so, i've gone crazy on them and put loads on there. bearing in mind the CD Player is around 16kg, the amp 20kg, and the tt around 10kg there's quite a bit of weight on each shelf.
Deleted member 108165
very therapeutic.
Cracking job bigfish... wanna come and clean mine? Free tea and biccies :)
Reactions: bigfish786
Paul Clarke
165
68
18,670
very therapeutic.
That's a lovely looking deck.
The acrylic material lends itself to all kinds of illumination pimping :) It is a lovely deck and not just in the looks dept. (y)
Reactions: Paul Clarke
Deleted member 116933
very therapeutic.
Changing the subject a little, Ive been keenly looking at that turntable myself, How has it been for you? reviews are glowing and I have a good grasp of what it sounds like but not what it's like to live with. Is there any frustrations, things maybe you wish you would have known before purchase that might give you pause if you were to buy it again? Many mention the motor can be fiddly to use is it really much of an issue?
@DougK as well as I can see you have the same
bigfish786
Moderator
Jan 29, 2013
396
210
19,270
Hi Millennia,
The turntable itself is a beautiful thing. An absolute bargain when you look at the parts on the deck.
The start button on the motor isn’t ideally placed, but it’s still useable, the motor is not directly connected to the plinth so there’s a tiny amount of movement that can occur as you turn it on, but only takes a second to centre it again.
A dust cover would have been nice, it’s something I’m considering buying at the moment.
But honestly there’s nothing about it that would stop me buying it again.
Hi Millennia,
Thank you kindly for getting back to much appreciated
I am amazed at the number of turntables these days that don't come with any form of dust cover.
Ill have to start making boxes again, used to do it at uni for my product design course to show off prototypes NOT cheap especially to get a museum grade finish
Museum grade sounds great. I’ll have one 👍😁 .The ones I’ve seen with the glass finish look nice (green tint to the cut edges)
LOL I don't know if I'm ready for the main stage just yet seems like there might be a market for it though. But yes the glass effect stuff is nice a lot of polishing is needed and special glue to keep the air out
Will always be expensive for postage, big , delicate and probably insured, imports duties are a lottery sometimes you pay sometimes you don't depend on what the border control is feeling like, I'm sure there's someone in the UK that can make them.
Friesiansam
589
454
11,270
ASK THE COMMUNITY
