New here and not really a hi-fi buff so please be gentle. So, after too many years of being lazy with music and streaming MP3's etc, I have decided I want to get back into listening to music properly and have dug out my old TT and vinyl and want to try and set up the components I already have as best I can. I do have a little budget which I will come on to later but, I'm really looking to understand what I can do with what I've already got to squeeze the best out of it. So, what have I got to play with:
Arcam Aplha 8 + Alpha 10 - Bi-amped to a pair of Mordunt Short 902s using 4 strand, solid core mains cable. Terminated directly to the posts at both ends but do have banana plugs somewhere if they will help.
Speaker stands are .. can't remember but, are the tri-pod type. Home made spikes which are 4" bolts turned to a point. I'm not sure they actually go all the way through the (thick) carpet and underlay though so , they will be getting a sharpen up. Legs are filled with coral sand - thinking of filling with concrete.
Main component stand I also can't remember, it is also on spikes and pretty steady, has glass shelves. Legs are currently not filled with anything - also thinking of filling with concrete.
CD player (which I'm not too fussed about) is a Cambridge Audio CD6. Also have a Sony BM10 for streaming Internet radio and MP3's (it's not bad actually). Internconnects are Silver Spirit.
TT is a standard (Original Goldring stylus) NAD 533 which has been stored for a ... erm, very long time. Have set up the tone arm as best I can. Cleaned the motor pulley, sub platter and belt with isopropyl. Also cleaned out the bearing well and bearing with the same (dark brown sludge came out) and re-filled with a quite light gun oil. Also added a spot of low friction PTFE tape to the bottom of the sub platter spindle.
So, I want to get back into the black stuff. When I said I have a small budget, I'm thinking along the lines of upgrading the platter/sub-platter, Stub end/counter weight and stylus (which has seen a fair bit of abuse). Looking at about £300 ... is the TT worth spending that on with the related components?
Been playing some records today which on the whole I'm OK with given what I've got but have two issues I think. Stereo separation is great but there's no real 'sound stage' as I understand it, it's either left, right or centre. Also, on some tracks, cymbals and words starting in 'S' are very ssss'y, if that makes sense. I'm reading things like wrapping the tone arm with PTFE tape and stuffing with cotton wool, is this worth playing with?
Any thoughts, advice would be vey much appreciated.
