Loading times on the oppo 103 since the new firmware update?
T
theflyingwasp
Updated the oppo 103 last week .since then I've had 10'or more Blu ray taking a heck of a time to load?
Deleted member 2457
Why did you need to do the update? Mine worked perfect and I never did one update.
T
theflyingwasp
As soon as they popped up I just updated the player ,I think I've had 4 since it was released.
Deleted member 2457
I would contact Oppo customer service, they are really good, I contacted them once:
http://www.oppodigital.co.uk/contact-us/enquiry-form/
Deleted member 2457
I would phone them up.
T
theflyingwasp
Thanks gel ,hey buzz lightclick no I've never factory reset it.i was under the impression the firmware updates improved the performance?
buzz_lightclick
I downloaded an update for the Oppo 95 a few days ago, and on the Oppo website it says an important step is to do a factory reset after you have downloaded and installed the file. (I never knew you had to do that before either). I'm not keen to do it as it means I will have to re-apply all my settings again, but if you're having problems with loading times maybe it will help?
T
theflyingwasp
Ah yes.... That was my concern,having to type in all my settings again.its not the end of the world but you know what I mean.thanks
