Lip sync using analogue outputs bluray
Hello
I have an older Av amp and i'm not wanting to change it if possibel. I had lip sync problems with dvd so have a delay device to correct this well. I would like to upgrade my ps3 for bluray maybe a sony bdp 760. Does anyone know if I can adjust lip sync on this if it doesnt work? thanks
Boca
19
Yes the Sony760 has lip sync adjustments in the menu, and you can adjust it as you are watching the DVD/Blueray
