Linux music software
dave_k
95
Hi All,
I'm getting my first Linux (Ubuntu) based netbook and wonder if there are any good music player software for it?
Any recomendations?
Merry Christmas
Dave
kena
104
As Binman said , I also have friend using Amarok happiliy, Foobar is possible but if you search internet it's does appear a bit tricky to get working so unless you like a challenge I guess it's Amarok .
dave_k:Thanks folks I'll check it out on Christmas day :)
Don't forget that Spotify works perfectly on Ubuntu 9.10.
Just install Wine: sudo apt-get install wine
Then run: "padsp winecfg" without the quotes, and select OSS driver in the Audio tab of the Wine config utility, and select "Emulation" in the drop down menu. Don't check the box for "Driver Emulation" at the bottom.
Then download Spotify for Windows from their website and double click it to install. You'll find it in Applications>Wine>Programs in the main menu after you've installed. (Top left of screen.) You can also drag the icon to the desktop or either panel to create a direct shortcut.
More info on setting up the sound here: http://blog.paulbetts.org/index.php/2007/05/27/make-wine-and-pulseaudio-get-along/
dave_k:
Hi All,
Any recomendations?
Merry Christmas
Dave
As for music players you are really spoilt for choice; there's Rhythmbox (already installed), Amarok, Songbird, Banshee, Audacious and many more.
I personally like Rhythmbox for it's simple layout, which is kind of like iTunes with browser columns for Genre, Artist and Albums.
