LG WOW Orchestra
kopaturex
I want to buy my first soundbar. I'm deciding between the Samsung HW‑QS750FL, the LG S70TRL and the LG S90T. For me it is important that I get a deep sound with a lot of bass. Currently, the equalizer on my tv (LG G4) is set to boost the low frequencies and reduce the high ones.
I don't know, if I should choose an LG soundbar, because of LG WOW Orchestra or get the Samsung, because it has according to reviews deep sound and a strong bass. Is WOW Orchestra really that good?
Does anybody know if I can separately control the equalizer settings for the tv and the soundbar with WOW Orchestra? If I can't set it separately will the tv have clipping?
Quick google shows LG Wow £500 soundbar essentially one speaker
Two Speakers , one per ear are always better spaced a few feet apart
Small active bookshelf with ARC Hdmi for your TV & if required add a Subwoofer for more bass
I can assure you with a LG sound bar you wont need to use the the WOW setting the soundbar alone with the subwoofer are sufficient .
you can change the bass mid and so on no need to use the WOW setting with no clipping and plenty of Bass .
