After 3 months, my LG 42PQ6000 still doesn't do black - just charcoal grey, even with all the gizmos turned off or low and brightness/contrast at ZERO!!
I'm wondering if mine is faulty because I'm not sure if you can return a TV just because you think it's a bit rubbish.
COULD SOMEONE ELSE PLEASE TRY THIS on their 42PQ6000 in a darkened room, which is how I always watch telly:
When first turned on, with no other source switched on if connected to AV1 (the set still defaults to AV1 even with no connection or signal) the whole panel lights up bright grey-white for a couple of minutes before settling down to dark grey. This initial milky over-brightness is noticeable when viewing programmes
Even after the TV has settled down, the small rectangular "No Signal" flashing moving warning sign when nothing is connected to an AV input literally lights up the whole screen. I expect it to light up the area immediately around it, but the ENTIRE screen lights up uniformly as if a full-screen backlight was providing the illumination. For the half second between flashes, the screen reverts to the kind of "black" you would expect to achieve in dark scenes while watching TV or DVD (instead of the trouser-grey that results if there is any other illumination anywhere else on the panel...)
I thought this was only a characteristic of LCD TVs, hence my purchase of a plasma previously well-rated @ £750. Is mine from a rogue batch, and if so how do I convince Richer Sounds?
