mullansson1:
plastic penguin:When it comes to pure SQ, the Leema will better any sub-£1,000 integrated. More of the question is: how many outputs do you realistically need? and do you have a TT? what size is your room?
Which qualities does the Leema has that the others don't? From what I've read it can sound a bit lean which is not something I normally like. Inputs/outputs is not an issue as I would only use two inputs and no TT, no sub.
MUSICRAFT:
Hi mullansson
From these three amplifiers i'll suggest Naim's Nait 5i as the Nait 5i works very well with Dynaudio's Excite X12's.
All the best
Rick @ Musicraft
The Naim is the only one of the three that I've actually listened to and it feels like a safe bet although I'm still curious what the others may offer that the Naim doesn't and vice versa.
Yes it can. However, that's about as negative as you can realistically get: in isolstion, however, any slight deficiency as regards as low-end bass is not detectable, and the slight leanness makes it the ideal candidate for Dyns.
The Pulse has detail, attack, timing and cohesion in spades; no-one could ever accuse the Leema of being anything other than enthusiastic. Without going into chapter and verse, if you take the good bits from a Cyrus 8 (detail, dynamics, rhythmic snap) and marry it with good aspects of Arcam (lovely organic, musical delivery) then you pretty much have the Leema Pulse.
