Hello all.
I was wandering if any of you have had the oportunity to compare directly the Klipsch Image X10 with the Sennheiser IE8? I have read the reviews and I'm pretty much torn between the two.
I have an iPod Classic and I'm looking at a 'serious' upgrade! Almost all of my audio files are lossless and those that are compressed are not less than 320kbps so I'm not worried about too much 'honesty' from the top-end headphones. I listen to almost all styles of music from classical and jazz to classic rock and NWOBM... definately no pop or dance though!
Basically I'm looking for the ones that are going to give me the cleanest, truest possible sound and I definately don't care for unnatural, OTT base.
I am currently swaying towards the Klipsch as I have seen them for £115, which seems like a bargain. The Sennheiser's I have found for £179.
I would really appreciate any thoughts of any of you who have had the chance to compare the two.
Many thanks in advance for your time and opinions.
CF
CF
