KEF X300A or DAC + some other speakers???
jazzisdrum
Hello,
My budget is around $1200 . KEF X 300A or separate DAC and other speakers? Thoughts ?
Thank you in advance!
S
Hi, welcome to the forum!
Do you mean you have an amp already, for your latter solution, or do you mean other active speakers that don't have an onboard DAC?
I don't have an amp. All I have is laptop and a pair of cheap active speakers 🙂 . Want to upgrade my sound system and got a $1200 budget. Laptop + DAC+ speakers OR Laptop + X300A OR Laptop + ........................? Any suggestions are appreciated !
S
S
BM5A Mk II plus an Emotiva XDA-2. Would be one solution. Search around for the best deals.
You could use an audio interface such as the Focusrite 2i2 to save money, sound quality should be the same, but you are not paying for features that you might not use.
PS. Was the laptop to be figured in the budget?
The Kef's are brilliant active speakers and the DAC's inside them are not too shabby, the only limit is that it will only go to 24/96 as the highest resolution but you can forgive them for that once you hear them in full swing, they really do pack a good punch for the money and I loved the sound that they give, making your HD soundtracks sound glorious!!
I own the kef x300a 's and wouldn't recommend them. The Kef eggs seem to be a better choice, with more connectivity options and sub port.
