Kef R50 upfiring atmos speakers
ideal av
Series1boy said:
ideal av said:
Series1boy said:
Does anyone have any experience of these with the Denon X6200?
yep
i`ve installed a denon X6200 with the R50`s a couple of times
and.... What is your experience with them, any good?
the overall sound was infact quite good but to get the desired Atmos effect, as with any upfiring speaker module, can take quite a bit of time and you may or may not get it at its best simply because of seating positions
its certainly not a plug and play upgrade and you need to be able to spend time in getting the angles and seating distance right before the WOW starts happening
the Denon drives them very well so you shouldn`t have any issues there
Series1boy
356
16
18,895
ideal av said:
Series1boy said:
ideal av said:
yep
thanks for your thoughts on this. I'm going to demo them and also look at front and rear heights as well before I take the plunge. I've previously used the onkyo up-firing and they were rubbish.
installing down firing speakers is too much of a massive job I'm afraid..
ideal av
try to take an objective view on what you might hear, depending where you are going for the demo could determine how good or bad they have been setup
installing the recessed in ceiling speakers may be a massive job to some but if done correctly look neat and i`ve never known them fail to impress, if decent speakers are used that is
good luck and if you want to listen to a good Atmos setup/demo then give me a shout
Allan
Son_of_SJ
325
Hello Allan@idealAV, you may remember that we briefly discussed the merits of Dolby Atmos on the AVForums. May I pick your brains please. My seating area in my parlour is covers about half of the room, the seats are shown in the photograph below. You can see that the seating covers three rows.
So, may I ask you these four questions:
1. Is there a maximum or indeed a minumum ceiling height that is suitable for Dolby Atmos? I ask because the ceiling height in my parlour and the bedrooms is almost eleven feet, whereas the ceiling height in the kitchen is only 7' 6".
2. Are those maximum and minimum ceiling heights different for upfiring speakers compared with ceiling-mounted speakers?
3. With either upfiring or ceiling-mounted Dolby speakers, would I be able to get the Atmos effect to cover the whole seating area in the parlour?
4. Which ceiling-mounted speakers can your recommend that will be of the same quality as the Kef up-firing Atmos modules, and how much do they cost?
Series1boy
356
16
18,895
Allan
do you have the r50s to demo?
ellisdj
377
Use height speakers instead of upfiring.
Front height, rear height or side front height - bit of effort, less than in ceiling but it will be worth it the long run. Its always going to be compromised bouncing sound by comparison.
I heard the R50 upfiring today actually - They were part of a demo setup but it was more of a video demo but I couldnt tell if they were on or off.
If they were off then fair enough - if on I got nothing from them - just so you know.
Series1boy
356
16
18,895
i am thinking of front and rear heights but just want to tick the upfiring kefs off my list to make sure...
Frank Harvey
567
But you wouldn't know what they were adding unless you heard the system with them on, and then with them off.
I'd say it's a good thing that you couldn't tell that they were on or not - speakers shouldn't draw any attention to themselves unless they're producing a discreet, mono signal... :)
Benedict_Arnold
661
I've posted before about the Klipsch RP140SA units. Do signed to fit where walls meet ceilings, speaker cones angled downwards.
Would be surprised if you couldn't get similar in the UK.
ideal av
Son_of_SJ said:
Hello Allan@idealAV
your ceiling heights shouldn`t really restrict you as levelling your speakers will/should sort out any issues you might have with distance/latency, i`d suggest if going with a lower ceiling fitment to choose a speaker with a wider dispersion characteristic
i`m not a fan of the upfiring modules, not saying they don`t work as i`ve heard them done properly and they sounded great, but you have a lot of variables/setting up to do with regards to distances, angles and seating positions, and your seating on the back wall i`d say would be not recommended at all to achieve the overhead spread
the KEF`s are the ones i`ve heard and they sounded good but to be honest the guys at Dolby labs would have spent days/weeks maybe longer getting it to sound the way it did so if your prepared to do the homework then good results can be had
we as installers always go down the MK/Dali route with great results but these may be out of your budget, it depends on how good you want it to be
Allan
ideal av
Allan
no i`m sorry, i don`t use upfiring modules of any manufacturer as there`s too much messing about with them getting all the variables right, distance - angles
as i suggest to everyone, if you can accomodate in ceiling speakers then that is the way to go for me and what we do on every installation
ideal av
Son_of_SJ said:
Hello Allan@idealAV
we as installers always go down the MK/Dali in ceiling route with great results but these may be out of your budget, it depends on how good you want it to be
Allan
