gasolin said:mond said:I haven't read the entire thread so not sure of your budget etc ,but what I think would definitely work for you is to add some supertweeters. This is exactly what I have done recently and the difference they make are stunning. More detail, more treble, and will make the sound more bright and less dark (without being over bright or fatiguing) I don't image you will consider this option as the tweeters will cost as much or more than your main speakers, but you may be able to find something on the used market. I use Townshend super tweeters which I can highly recommend. I have bought many a speaker from reviews only, as I generally buy second-hand so have taken a risk several times (including buying the supertweeters). I wouldn't worry about the numbers and what we can or can't hear within the frequency range as these tweeters effect the sound throughout the whole sound spectrum..... just don't ask me how they work!
If you did take this route you could use them with future speaker upgrades if need be or sell them on again when no longer required …
That takes away the advantage of coaxial drivers https://www.youtube.com/watch?v=hbc5GdM9RIg
Aah, well that particular system might not benefit from said supertweeters, but I daresay it’s also a far cry from the system of the OP !
That really is an incredible looking system, although it doesn't sound that great through my laptop speakers I'm sure it sounds amazing in real life 🙂
better start saving ........ for the hifi and the house to accomodate it!
