insider9 said:How did you setup your speakers? How wide apart are they? Is there any toe in? Are you using speaker stands? How far are they from walls and what height are they compared to the listening position? Where is your listening position in the room?
I'd genuinely look at cables as one of the last tweeks, definitely not the first. Get the room right, the setup, source etc. and then if you want change cables.
They are 2.40 meter apart, 30 cm from wall and my listening position is 2.50 meter away. This is the best set up after several tries. I tried a little toe in but prefered them to be straight. I have them on Atacama HSM 1.1 stands. Only issue could be they are close to side walls but for the moment I can not change that.
